I have two parts that I would like fabricated from steel. I've designed the parts so that they should be able to be fabricated using 1/32" slitting saws (possibly ganged) and from 1/2" x 1" x 6" bar.
The two units are part of a press that squeezes thin plastic and embosses it with a pattern. I would like to replace the parts in order to change the pattern. (The two pieces that I need do not interact with one another, each presses onto a flat receiving surface).
The top surface of the pattern needs to be a flat plane. The pattern itself doesn't require an excessive level of accuracy - I'm assuming +/- .005" is reasonable to achieve?
The hole sizes are sized for tapping M8 1.25 thread.
All dimensions in inches and fractions of an inch.
Destination: Vancouver, BC or Blaine, WA 98230
Please message me via this site if you have any interest.
Thanks.
Rusty
** Download complete PDF Files here:
https://dl.dropbox.com/u/66199725/Rusty1.pdf
https://dl.dropbox.com/u/66199725/Rusty2.pdf
