After around a month of design, I think that I might be ready to start putting together my second CNC. My first was all plywood and used allthread for the drive; as expected, it cut like a wet noodle and took forever to do it. For that reason, my new design's main goal is to retain as much stiffness as possible. I am hoping for a solid machine that can cut wood fast, engrave fast, and do a bit of light aluminum cutting. My budget is ~$250 (my old router will be glad to donate the electronics), but I can increase it if absolutely necessary.
My current design is, in a sentence, a mishmash of ideas from every commercial kit out there. The base is made out of 2x4's (Solsylva style) , and has 1/4" thick CRS on both sides (CNCRP style).
The gantry consists of a 2x4 beam of hot rolled 1/8" steel tubing with two 2x6x1/8" blocks of aluminum tubing acting as risers. The linear bearings are homemade clones of the CNCRP bearings (Momus style), and are bolted onto the bottom of the gantry risers. The 2x4 that rests on top is also the main rail that the z-carriage rides on (xyz-cnc style). A plywood plate attached to the side holds the bottom linear bearing in place and holds the motor/linear motion junk in place (don't ask why I made it blue). A small section of 1/4" steel angle also serves to reinforce the joint between the aluminum and steel.
The z-carriage is just a bit of 1/4" aluminum plate with a number of linear bearings bolted onto it. The portion that rides on the 2x4 steel beam uses 6082RS (skate) bearings, and the portion that guides the z axis uses 1/2 OD bearings with shields. The z axis itself is a solid block of 3/4x3 aluminum bolted to a 1/4" thick aluminum flat that acts as a rail.
#25 chain is what pushes the whole thing around (Buildyourcnc style). I have 425 oz.in motors and can use chain to reduce them by 2x, so I should have 1.5 inches per rotation. Since my CNC is mostly steel and aluminum, I should be able to put around 100 pounds of tension in it. The Z axis uses allthread.
My old CNC router will be making some of the wooden components for the new one (once the new one is done, I'll replace the wooden parts with aluminum versions). I have access to a small mill, so I should be able to drill most of the holes with a good amount of accuracy. The router is from harbor freight (probably not a good omen).
So, am I ready to build this? If you see anything that looks off, I'd love to know. I am determined to make this machine perfect, and I won't start until it gets there.
