585,753 active members*
4,473 visitors online*
    1880
    older Brush Servo amps
    Does anyone know how the HAAS MOCON comunicates with the drives?
    Ie. PWM, step dir, +-10v ect...
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    1880
    Anyone?
    thanks
    Michael T.
    Mar 2005
    1498
    060218-2156 EST USA
    miljnor:
    Limited info in the manual.
    P3 on servo board. PWM and H drive control signals from Motor Interface and overcurrent sense block. 16 KiloHz, Ilimit 20-22 A, nominal supply 160 V. Continuous power output limited. This determination is in "Motor Interface". Send your fax number if you want a copy of the several pages. Not much information.
