585,987 active members*
4,494 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Parting out a 1994 Cincinatti Arrow 500
    Dec 2007
    5
    I am going to part out my Arrow 500. The only part that I need and cant find is the Spindax spindle drive, so all other components are working. Here is a list.
    X drive $700
    Y drive $700
    Z drive $800
    X motor $700
    Y motor $700
    Z motor $800
    power supply module $900
    memory module $900 (has new batteries and files loaded)
    servo module $800
    I/O module $800
    motherboard $1100
    main transformer $600
    spindle motor $1200
    coolant pump $250
    control panel $400
    DC braking resistors $500
    all these components work. I just cant find a spindle drive that I can make work and I'm tired of beating my head against the wall. I have a video of the machine moving to show that it runs other than the spindle turning. although the spindle turns smooth when wired around the spindle drive.
    thanks for looking
    Andrew 423-736-0422
    Feb 2007
    4553
    Andrew,
    Why cant you just use a over the counter VFD?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2007
    4553
    Andrew,
    Emerson may provide tech support for a replacement drive.
    http://www.emersonindustrial.com/en-..._a_Spindax.pdf
    Jeff...
    Dec 2007
    5
    I appreciate the replies, but I am not knowledgeable enough to get any further than i am now with this project, so i have decided to scrap it and start over.
  1. Cincinatti Arrow 500 Control Techniques
    By Slick27 in forum Cincinnati CNC
    Last Post: 08-14-2014, 08:07 AM
  2. Hello from new Cincinatti Arrow 500 owner...
    By pete from TN in forum Cincinnati CNC
    Last Post: 05-16-2012, 04:50 AM
  3. Cincinatti Arrow 1000 Down For the Count
    By david_culler in forum Cincinnati CNC
    Last Post: 03-14-2010, 01:22 AM
  4. cincinatti milacron arrow 750
    By kevmor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-11-2008, 04:10 PM
  5. Cincinatti Arrow Service Needed
    By mlkaiser99 in forum DNC Problems and Solutions
    Last Post: 09-14-2007, 07:42 PM
