Originally Posted by
kylerxiii
any time I try and run my 3D toolpath for my part it herks and jerks the whole way through no matter how high i have my feed set. I spoke to someone at fagor and they mentioned enabling G51 he said he would e-mail me some info on how to do that but he must of forgot :/
a lot of 3d code is short point to point moves , jerkiness is common on machines that don't have a decent look ahead or a high speed machining option . Jerkiness can also increase as the feed rate is raised because the machine control is now more or less not keeping up to the code at an even quicker rate . If you run it at a slower rate that the control can keep up to then it should smooth out some . For roughing I'd suggest opening up the machining tolerance in order to reduce your codes and use arc fit when possible
Chances are that the g51 code your rep referred to is a look ahead command which should help in smoothing out the code but probably won't fully cure the issue if hsm isn't an option . Fagor is one of the few controllers that I haven't worked with so I'm just speculating as to fagor's g51 (though I'm sure I'm right) . Google is a great tool and I'm sure that you can find more info in five minutes than what he'll be sending you
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
