I am trying to figure out how to disable the automatic feed rate adjustment for this machine. We are using radius offset cutter comp in a lot of our programs, and we end up needing to double our feed rates because whenever we are doing an internal helical ramp the controller is automatically cutting the feed rate in half.
Does anyone know if/where this parameter is? I am having trouble finding anything in the manual. A PDF of the manual would be nice to so I can ctrl-f through it.
It's a Fanuc 0iMD controller if that helps.
