585,994 active members*
4,675 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > How to set proper Spindle bearing preload?
Results 1 to 14 of 14
    Jan 2010
    294
    I'd like to hear some thoughts on how to correctly set preload of a spindle. I figured it was a matter of testrunning and monitoring for heat issues. Too much heat= too much preload?
    Is there more to it?
    www.steelplinkers.com
    Mar 2006
    2712
    As usual, depends. Preload can be built in by the manufacturer. If that's what you have, the preload is set by clamping the bearings together.
    Preload can be set by grinding a bit from either spacers or inner/outer bearing ring faces. NOT A JOB FOR THE INEXPERIENCED. You will be dealing with microns of material removal, absolute parallelism and perpendicularity of bores to faces of bearings/spacers.
    Better to pay the piper and order your bearings with the proper preload built in.
    Dick Z
    DZASTR
    Jan 2010
    294
    I'm speaking of a spindle setup that uses tapered bearings. Spanner nuts on end of shaft are used to set preload of bearings. Im curious what is tight enough- and what is too tight?
    The way they are currently being rebuild inhouse- the spindle shafts are so tight you can barely turn them by hand. The bearings are failing in short fashion ( we have roughly 50 of these spindles in use) It was previously thought to be a non-greasing issue, but after rebuilding a small mill spindle at home and having issues with heat and correct preload, I was thinking the problem is with high heat from tight preload.
    Jan 2010
    485
    Timken has engineering literature, here - http://catalog.timken.com/WebProject...Code=trb12flx# Different settings for different uses.
    15362
    binfordw
    So the part you are missing is a spacer between the 2 Bearings, you machine this spacer (tube) to give you the right preload on the bearings, you then can not over do the preload unless the spacer is to short
    Mactec54
    Aug 2011
    388
    Agreed with Dick, packrat, and Mactec54. All bearings but especially tapered rollers are very sensitive to the preload distance / spacer length. Timken's double-row bearings (TDI, TDO, and older automotive SET series) or Spacer Assemblies make this easy, as the preload distance is built-in to the bearing/spacer. These also need a predefined press fit on the shaft. If the spindle is using 2 single row bearings, I'd look into ordering a spacer assembly.
    Automotive wheel bearings are often torqued to around 150 ft-lb, but that simply compresses the inner rings together to their set distance. For a non-spaced assembly, a torqued nut isn't a good way to set preload -- thread friction is not consistent, so the preload is all over the place. Bearings can fail by heat at higher speed or excess contact loads at lower speed (and other ways).
    Depending on the application, if a spacer assembly isn't feasible, another option might be a Belleville washer on 1 end of the spindle. As long as the washer isn't bottomed out, the load is reasonably correlated to the compression distance. But if the spindle has both push and pull loads, neither one can be more than the Belleville compression load or the spindle will have 'slop'.
    David Malicky
    Jan 2010
    485
    Wow, 150ft/lb on wheel bearings! Think you mean 150In/lbs, then you back-off nut one flat. End play of .005 -.008 is what you shoot for.
    Aug 2011
    388
    Oh, there are a number of different designs and methods--light trucks and some cars often use a method similar to the one you describe (or with cotter pin). For most recent cars, common practice is indeed 150+ foot-pounds (no cotter pin or tabbed lock washer). I think the inner races are ground to give slight preload, as I've not detected any slop in the ones I've worked on.
    http://www.vsm.skf.com/~/media/Files...ve/457377.ashx
    Porsche 911 is 340 ft-lbs -- now that's a breaker bar!
    David Malicky
    15362
    packrat
    This is a normal number, for auto front hubs,there are many that are much higher than this, older types & trucks, trailers Etc are similar to what you have described
    But none of this has anything to do with what binfordw, wanted with his spindles
    Post #1 I'd like to hear some thoughts on how to correctly set preload of a spindle. I figured it was a matter of testrunning and monitoring for heat issues. Too much heat= too much preload?
    The only way to fix his problem is what I said in post #5
    Mactec54
    Jan 2010
    485
    packrat
    Or my post #4 going to Timken Engineering manuals for the type bearing arrangement the OP has. Which we don't know, other than tapered roller bearings at each end. Not all bearing set ups use spacers.'
    The hub bearings you guys were talking about don't have an adjustment, wasn't even thinking of that type when I answered. They come from the factory with the .005-.008 end play built in. With out it they would overheat and die, fast.
    15362
    packrat
    They may have .005 to .008 before assembly , but once locked up, assembled correctly, they have zero end play, so Not correct at all
    Any machine spindles that are of any use at all, will have spacers to control in this case the timken bearing preload, no matter what type of bearing you use in a machine spindle, precision spacers are needed to have a stable spindle
    Mactec54
    Jan 2010
    294
    I appreciate the help guys.
    The spindle setup (these are used on a chamfer-lathe machine) Uses a tapered, single row bearing, a radial bearing behind that, and another single row tapered bearing at the opposite end of shaft.
    The drawings do not show a spacer/sleeve being used. However, there seems to be a couple different variations, I did find one that has a spacer. Why they do not all have spacers- Im not sure.
    Aug 2011
    388
    If it fits or can be made to fit, I'd suggest replacing the 2 nose bearings with a TDI or TDO pair (or possibly an automotive SET cartridge with built-in seals) -- then the preload is factory set, as Dick Z suggested. Or a pair of duplex ground ACs ($). The tail end usually gets a radial floated in the housing, unless there are heavy loads on that end, too, in which case a needle roller or another TDI/TDO (clamped to shaft but floated in the housing) is appropriate.
    Slight preload gives the longest life for tapered rollers: http://www.pirate4x4.com/tech/billav...20pre-load.pdf
    SKF shows optimal preload at around 0.05*C: http://www.skf.com/files/005031.pdf
    Tapered rollers are very stiff and so very sensitive to preload distance, so it's very hard to grind a spacer just right, as Dick Z said. Usually, spacers have to be custom fit to each housing -- more cost and more to go wrong. If the spacer is slightly too short, the bearing overloads and fails. Too long, slop. Even if perfect, as the shaft heats up, the preload is thrown off. That's why most designs use TDI or TDO -- it keeps the highest precision requirements inside the bearing assembly, makes the preload ~insensitive to shaft temp, is extremely stiff in all directions, is easiest to make, easiest to service, most reliable, and least cost. 7 wins!
    David Malicky
    Mar 2006
    2712
    Precision tapered roller bearings for spindles are $$$$$$$$$$$ also. However, they can usually handle heavier loads than A/C bearings. A/c bearings can handle higher speeds.
    I usually use sealed A/C spindle bearings. If I need more "heft", I use multiple pairs of bearings, sometimes with spacers. The spacers add to stiffness and spread the heat generated by the bearings to more area of the housing.
    FWIW, latest one has two pairs of sealed A/C bearings separated by a roller bearing (matched bore and O.D.sizes). These are captured on the nose end and a floating radial ball bearing on the opposite end.
    Dick Z
    DZASTR
  1. AC Bearing Preload
    By feederic in forum Benchtop Machines
    Last Post: 11-19-2012, 02:33 AM
  2. DIY Spindle bearing preload
    By Beowulfenator in forum Mechanical Calculations/Engineering Design
    Last Post: 10-01-2012, 06:12 AM
  3. preload on spindle bearing
    By adryan in forum Uncategorised MetalWorking Machines
    Last Post: 06-21-2010, 11:59 PM
  4. Spindle bearing preload
    By chevyguylt1 in forum Fadal
    Last Post: 05-04-2009, 03:53 PM
  5. preload on spindle bearing
    By adryan in forum Vertical Mill, Lathe Project Log
    Last Post: 05-26-2006, 01:51 PM
