585,996 active members*
4,482 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Using Edgecam on a wabeco mill
Results 1 to 7 of 7
    Jun 2006
    10
    Hi I was wondering if anyone is using Edgecam on a Wabeco mill? I am considering buying a Wabeco CC-F1410LF high speed CNC Mill for home use but only if I can generate programs for it using Edgecam. It uses G code & I have been told that a Fanuc om code will work on it. So I am in need of a post that will output the correct data. Or could anyone edit a post to give the correct output. I have a list of rules that the code must follow. The machine is supplied with nccad professional software, but will be better if I can use Edgecam. I think NCCAD is made by Kosy?
    Jun 2008
    125
    What version of Edgecam are you running? Look on the help tab of Edgecam if you're not sure.
    Jun 2006
    10
    Hi, Thanks for the reply. I am using 2009.20
    Jun 2008
    125
    Sorry, can't help you. Only got 2012r1 and 2013r1 on my pc. Maybe someone else can help.
    Should be easy enough to create a simple fanuc post. Use the adaptive iso template (only ever use adaptive posts) and tweak it to suit. Should take too long ;-)
    Jun 2006
    10
    Thanks for your interest in my thread. Yes perhaps someone else might come forward with help. If I ever upgrade though perhaps I could come back to you?
    Cheers
    Jun 2008
    125
    Sure, would be glad to help.
    Aug 2012
    I'm Wabeco CC-F1410 HS LF user (since 1 year), using nccad basic. If that can help you, I can test a gcode program.
  1. Wabeco Mill
    By labuda in forum Benchtop Machines
    Last Post: 11-25-2021, 11:05 PM
  2. Mill/Turn in Edgecam 12
    By Ortho in forum EdgeCam
    Last Post: 03-13-2009, 03:18 PM
  3. wabeco mill.
    By eddythefly in forum European Club House
    Last Post: 01-13-2009, 09:37 AM
  4. Problem with manual machining on a WABECO F1210E CNC mill
    By dynosor in forum Benchtop Machines
    Last Post: 06-13-2008, 08:06 PM
  5. Can this Wabeco mill be converted to CNC
    By jaru-eri in forum Benchtop Machines
    Last Post: 06-28-2006, 11:29 PM
