585,712 active members*
4,014 visitors online*
Results 1 to 10 of 10
    Jul 2005
    261
    3m model c "THND"
    I have a system 3m model C, I can't seem to clear "NOT READY", machine won't jog. "THND" is on the screen, when I switch selector to "JOG" this doesn't seem to change.
    When I hold "RE-MOVE / 2ND LS" switch up, the "NOT READY" goes away, screen switches to coordinates (0 for all axis) - but still no jog movement.
    Can anyone advise please? Thanks.
    --Erich
    WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
    Nov 2007
    28
    Put Machine into handle mode x 10 and move axis this way
    Jul 2005
    261
    x1 x10 or x100 will not move it. Also selector switch when set to "JOG" does not display JOG on the screen.
    Nov 2007
    28
    Hold 2ndLS switch on while trying to move with handle.
    Jul 2005
    261
    Ok just an update; I found another old sheet with the parameters written down that were alot different then what I had, after manually entering them - the system will now jog, move carousel, turn on coolant - if I have the override switch set on, but still stuck in "NOT READY"
    I tried to read the 5 manuals they have for it but could not come up with a troubleshoot guide for "NOT READY".
    --Erich
    Aug 2011
    2517
    if you hold 2nd LS switch up (like before) does 'not ready' go away?
    Jul 2005
    261
    NOT READY goes away when I put the "2nd" switch up. I fixed the issue, the limit switch for y and z were both jammed.
    -- new problem, the tool changer does not appear to work
    I advance carousel with the buttons, however the tool number sticks at "1" on the BCD.
    Dec 2014
    9
    Dec 2014
    9
    Sep 2021
    Hello
    I have a Kitamura Mycenter 1 with a Fanuc OM controller. The parameters were erased by mistake on the controller. I obtained a copy of the parameters from the manufacture and have re-entered them. Upon power up I do not get any alarms on the CRT but I do get "not ready" in the lower left corner. I also get "THND" on the CRT in the position normally displaying "MDI", "EDIT" etc. Any help would be appreciated.
  1. Fanuc OM "THND" on CRT
    By CNC-new-be in forum Fanuc
    Last Post: 10-04-2021, 06:21 AM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. Replies: 2
    Last Post: 12-12-2013, 05:47 AM
  4. Replies: 4
    Last Post: 05-28-2013, 09:20 PM
  5. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
