585,722 active members*
4,262 visitors online*
Results 1 to 6 of 6
    Nov 2003
    314
    Chineese 24v power supplies
    There are lots of 24v 10-15A psu on ebay for small money is anybody using them
    24v psu
    Nov 2003
    314
    Ok I will be the guinea pig
    Nov 2007
    483
    my impression is people would want higher voltage so they could run thier steppers faster, if you are running steppers. It very much depends on what motors you want to run. Without the power requirements for your motors you can't determine the optimal power supply required.
    Jun 2007
    3891
    i have some of these chinese supplies via xzero. i use them only for accessories. the main thing with these supplies, whether 24 or 48v is that they drop voltage ALOT under load. so if say, you have 3 x 3 amp steppers and use the 2/3 load rule, youll want a supply rated for 12 amps or more to get proper consistent behavior.
    Nov 2003
    314
    I have been running machine on 12v since I built it 24v would be a big stepup for me
    I am using 3 vexta 2A steppers hobbycnc board.
    I was more curious to know if anyone has bought any of these chinese PSU's and were they any good.
    If the 24v 15A one works it will be perfect for me.
    Apr 2005
    253
    Well i think its cheap enough to get one to try, am sure when your machine is running its only using a few Amps so there is plenty of over head available that you should have no/minimal voltage drop.
    Get one and let us know how you get on.
    I'll get it finished sometime after I start it.....
  1. Power supplies
    By ttarter3 in forum Stepper Motors / Drives
    Last Post: 01-06-2013, 06:01 AM
  2. Power supplies
    By cd_edwards in forum Stepper Motors / Drives
    Last Post: 11-22-2011, 06:38 AM
  3. Power supplies for UHU
    By contactirfu in forum UHU Servo Controllers
    Last Post: 09-18-2009, 08:05 AM
  4. These power supplies useful?
    By jlawren6 in forum CNC Machine Related Electronics
    Last Post: 08-26-2004, 02:19 AM
