585,996 active members*
4,834 visitors online*
Results 1 to 11 of 11
    Sep 2003
    4
    Smile New CNC Controller Program for DOS
    Hey, Guys
    I have written a CNC Controller Program running uder DOS. It has Constant Speed Contouring by default and Six Work Offsets and...
    Anybody who want to experiment with this can send me a mail. I will send you the program file and instruction.... Hope that you can give me some feeback and will happy with trying this new bee.
    Jun 2003
    70
    Ahha tried to do constant contouring for the last five years. Maybe you should talk to them about what you have.
    Jim Short
    www.tahlinc.com
    2139
    Sure, send the program my way.
    [email protected]
    Eric
    I wish it wouldn't crash.
    Apr 2003
    159
    I also would love to try your program if you don't mind..Thank you
    [email protected]
    Sep 2003
    4
    Hey, Guys
    Thanks for your interest. I am at work now. Will send you the program few hours later.
    manfong
    Apr 2003
    307
    Manfong,
    I would like to try it out also.
    [email protected]
    Thanks,
    Chris
    35538
    If you didn't get the email I sent you, send me one too.
    ger21 at comcast.net
    Aug 2003
    69
    Testing software.
    If you are in need of more software testers, than maybe i would like to give it a go. My CNC machine is not finished, just yet. So i'm not sure when i'll start with testing. Could take a few more days, weeks at most.
    You could send it to me at : [email protected]
    Thanks and Greetz,
    Ed.
    Not the horse, of course of course...
    Building my own Scrapheap challenge CNC, or is it Junkyard wars CNC?
    Apr 2003
    307
    Manfong,
    Thank you for the software. Unfortunately, I am unable to use it in it's present state.
    The problem is that the pinouts from my printer port do not match the ones required in your program. I am using a hardwired controller board (Piker 4X) and am unable to change the pins without a breakout board. I may need to add that in the future but for now I don't have one. Relay controls would be handy also.
    The other problem is that there is no accomodation for home and limit switches. Though that wouldn't prevent me from using the program, it is a safety issue.
    Good luck with your program.
    Chris
    Sep 2003
    4
    Hi Chris
    Thanks for your input. The program is still under development and new functions and features will be added in future version. I am not sure whether I can make the step and direction pins being configurable as this will need a major change in the program but the axis limit switchs sensing and homing function will definitely be added in the next version. The future version will also enable the NC program to turn on and off of the spindle and coolent..
    manfong
    2139
    If I were you, I would make the step and dir pins configurable now, while you can, and before you invest too much time. Nobody uses the same boards, and without being able to configure all the parallel port pins to suit would eliminate almost every potential user. With software like Turbocnc, Cncpro, and Mach 1 out there and working great, why would anyone want to use (or even try) yours, if they have to make a special breakout board for thier controller?
    Just my 2 cents.
    Eric
  1. Open Source CNC Controller Specification
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 12-05-2005, 04:58 AM
  2. Learning to Program CNC Turning Center
    By Farmer in forum G-Code Programing
    Last Post: 09-12-2005, 06:03 AM
  3. 3D or 2D MAXI Style Hobby CNC PWM Controller!
    By icm in forum News Announcements
    Last Post: 01-05-2005, 03:36 PM
  4. HELP: Controller to PC Program retrieval
    By virtualoha in forum Uncategorised CAM Discussion
    Last Post: 09-29-2003, 07:12 PM
