585,908 active members*
3,805 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Alignment - to center or not to center?
    Mar 2013
    Hi there, just wondering what people's thoughts are on the importance of having the laser beam hit the center of each mirror when aligning?
    I have read some instructions that say to get the beam centered, and some that say there is no need so long as the laser hits the same place at both extremities.
    Anyone got any thoughts on whether it is worth trying to get the beam hitting the centers?
    Thanks in advance!
    Nov 2008
    644
    I found that its important that the beam hit the center of the lense. Since you tend to work allignment from the tube to the lense it only makes sense to try to hit the center on each lense as you go. However it is a perfectly flat surface and it shouldn't matter where the beam bounces off.
    Nov 2010
    787
    No need.
    Except last mirror where it should.
    CNC lasers, constructions, service
    Oct 2010
    71
    No need to hit the exact center of the mirrors. As long as the beam is parallel to the flight path you will be ok. You do need to get the beam in the center of the lens though.
    Oct 2008
    16
    Re: Alignment - to center or not to center?
    Should be centered due to simplicity on further mirror alignments or else the cut will not be perpendicular to the cutting plane as the focal point line will be slightly diagonal in a 3d sense..
    On other words.. (to be more correct) actually only the focus lense is important. If the laser beam does not hit on the center of it then the cut will not be perpendicular to the plane and geometric distortion may occur..
  1. Center Alignment with Mastercam -> Create -> Letters
    By mikefalkner in forum Mastercam
    Last Post: 04-17-2016, 04:49 AM
  2. V.12 Mill Pro Selecting center-cut VS non-center end mills.
    By countryguy in forum Dolphin CAD/CAM
    Last Post: 05-20-2014, 01:27 AM
  3. Table Slot Center -to Center distance
    By bostosh in forum Haas Mills
    Last Post: 10-25-2010, 03:41 PM
  4. Recommended center diameter for center rest
    By CAMCRASH in forum MetalWork Discussion
    Last Post: 03-30-2010, 06:58 PM
  5. center drilling: Out of center
    By skipper in forum MetalWork Discussion
    Last Post: 03-01-2008, 07:50 PM
