585,959 active members*
4,867 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Mounting BK12/BF12 Ballscrew Supports
    Mar 2013
    Question Mounting BK12/BF12 Ballscrew Supports
    Hello,
    I am building a CNC machine based on Chinese ballscrews and rails, with aluminium frame. The ballscrews are supported by BK12/BF12 blocks, and I include part of the datasheet in the picture bellow. I have a pretty basic question: what screws do those parts expect? I can see that the four vertical mounting holes are 6.6mm in diameter. My first reaction is that a metric M6.5 or imperial 1/4 inch hex socket screws would fit, but M6.5 is a bit exotic and imperial screws for metric part... sounds weird. Or is this all not important? I worry that the part will not be supported well if I use "wrong" diameter screws.
    Also, there are four smaller holes perpendicular to the 6.6mm ones (they are marked as fi d2 and are 5.5mm) - are they just for alternative way of mounting?
    Aug 2011
    388
    Those holes would normally be for M6 bolts, but 1/4" would fit, too. 1/64" or .5mm are common clearances, and allow a tad of adjustment if the threads aren't quite in the right spot. The actual position is held by the clamping force, not the bolt locations.
    The 4 smaller holes could be for alternative mounting, but I find those are ideal for the motor mounts--easy to get the motor axis colinear with the ballscrew axis that way.
    David Malicky
  1. Source for Bearing in the BK12/BF12 Bearing Blocks
    By localguy65 in forum Open Source CNC Machine Designs
    Last Post: 01-03-2013, 01:27 PM
  2. How place Ballscrew into BK12
    By samsagaz in forum DIY CNC Router Table Machines
    Last Post: 02-29-2012, 05:10 PM
  3. rm1605/bk/bf12 ballscrew questions
    By frige in forum DIY CNC Router Table Machines
    Last Post: 03-31-2011, 01:16 AM
  4. Ballscrew machining and end supports
    By alexis221 in forum DIY CNC Router Table Machines
    Last Post: 04-12-2008, 06:00 PM
  5. Ballscrew mounting
    By m_c in forum Linear and Rotary Motion
    Last Post: 03-11-2006, 10:51 PM
