586,011 active members*
4,215 visitors online*
    Mar 2013
    Mazak M32: Check sum error before boot
    When I turn on the machine, it says "System Loading" and the green bar counts down from 100%. After about a minute or so, it says 'Check Sum Error'. The floppy drive seems to load other floppy disks fine, such as the parameter disk, so I dont think the drive is the issue.
    In the book, it says for alarm "Sum Check Error" ( I dont know if Sum Check and Check Sum are synonymous) it says: "The contents of the system software have been lost." "Insert the system floppy disk into the drive once again and reload the system"
    But I am trying to load the system floppy. Picture below.
    Re: Mazak M32: Check sum error before boot
    Hello, today in the morning my machine woke up with the same failure like yours had. :drowning:
    How could you solve that problem?
    Thank you.
    May 2013
    5
    You will potentially have to do a wipe (dipswitches on cards) and reload everything.
  1. Mazak Quick Turn 6T wont boot up
    By Boobo-oobo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-19-2018, 06:59 PM
  2. Hurco KM-3P Boot Error
    By nuzmeed in forum HURCO
    Last Post: 08-18-2011, 06:53 AM
  3. Fanuc 11M Check Instruction during boot
    By KLampkin in forum Fanuc
    Last Post: 05-09-2011, 01:55 PM
  4. Mazak won't boot up
    By tekna in forum Australia, New Zealand Club House
    Last Post: 03-31-2009, 10:13 AM
  5. A2100/NT boot error
    By kentsui in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-14-2008, 10:44 PM
