585,926 active members*
3,971 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > mycenter 1 - fanuc 3m model c / atc problem
Results 1 to 8 of 8
    Jul 2005
    261
    The led display does not seem to move away from "1" when I advance carousel. When in MDI mode, do "M6 T2" does NOTHING. Just did a master reset (accidentally) and wiped parameters - just put them all back in. I understand there is a tool macro that is executed? I copied from another machine - not sure where supposed to go #9001? 9000? 9020?
    Can anyone advise please?
    WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
    May 2013
    I think, usually is 9020 program with tool change sequence.
    May 2013
    128
    9001
    Re: mycenter 1 - fanuc 3m model c / atc problem
    I am also having the same exact issue, not sure what to do from this point on. Can someone please shed some light on this topic please? My machine is a 1983 Kitamura Mycenter1 with Fanuc 3M-C control VMC
    Hola,soy nuevo en el foro. Le comento que tengo una KITAMURA MYCENTER 1 FANUC OM,El cual me esta dando dolores de cabeza últimamente. Cuando enciendo la maquina la luz INDEX del pulsador permanece intermitente y nose como solucionarlo, soy de Mendoza argentina y aquí todavía no encuentro quien lo pueda solucionar. Me urge mucho poder repararla, cualquier comentario con respecto al tema me seria de gran ayuda. Graaacias
    You have pictures of your team's problem, I can support you:
    [email protected]
    Feb 2018
    Quote Originally Posted by alexeye169 View Post
    Did you solve your problem?
    Do you recommend that CNC (kitamura mycenter 1 fanuc 3M)?
    I'm going to buy an equal but I've never worked a kitamura
    Apr 2007
    144
    The Kitamura Mycenter 1 w/Fanuc 3M control does not use a 9001-macro for the ATC. It is completely controlled by relay logic.
    * Confirm that the ATC is retracted
    * Confirm that the ATC is UP
    * Confirm that the spindle tool is CLAMPED
    * Confirm that the ATC TOOL POCKET opposite the spindle is the number shown in the LED window.
    Note: The pocket opposite the spindle must always be empty.
    Command Txx M06; in MDI. What happens?
  1. Replies: 14
    Last Post: 01-28-2014, 04:51 PM
  2. Replies: 0
    Last Post: 11-02-2013, 06:47 AM
  3. Fanuc Model 12 spindle problem
    By kalawa in forum Fanuc
    Last Post: 07-14-2010, 05:09 AM
  4. Fanuc OT- model A problem
    By rai in forum Fanuc
    Last Post: 02-23-2009, 03:25 AM
  5. Replies: 6
    Last Post: 05-28-2007, 03:50 AM
