585,712 active members*
3,935 visitors online*
    Aug 2011
    14
    G42 Hurco problem
    Hi all just wondered if any of you have seen this problem?
    I'm milling a simple external rectangle, 503mm X 550mm and I'm using G42 comp. (on a HURCO BMC30 Ulitmax 3)
    All is fine except when the machine come to the edge of the rectangle to move down the other side it's rounding the corners of the part.
    I know it's G42 that's doing it, as when G42 is removed it cuts square corners.
    Apart from that it cuts as expected.
    Any ideas?
    Jun 2008
    1103
    Your tool size sounds incorrect.
  1. hurco VM1 remote jog problem
    By Racine Mechanic in forum HURCO
    Last Post: 02-10-2011, 04:01 PM
  2. Hurco ATC arm Problem
    By mpi in forum HURCO
    Last Post: 06-29-2009, 01:13 PM
  3. hurco km3 problem
    By junaid.wahid in forum HURCO
    Last Post: 11-17-2008, 09:26 AM
  4. Hurco BMC 30 problem with spindle
    By electromech in forum HURCO
    Last Post: 04-19-2008, 05:43 PM
  5. HURCO ATC problem
    By jawwad in forum DNC Problems and Solutions
    Last Post: 11-09-2006, 08:26 PM
