585,991 active members*
6,540 visitors online*
Thread: G320X PID
    May 2012
    32
    G320X PID
    New to servo's and we are having some difficulty in getting the CNC mill to move correctly using servo's.
    This is a CNC retrofit that had servo's installed already but the control software was DOS only and we were having problems
    with axis movements so an upgrade was decided. Using new motors with ATM102 encoders and G320X drivers, MACH3 is being
    used since we have experience with this on some home built machines but using steppers.
    My question is in regards to the sequence of adjusting the pots on the G320X drivers, we started out with all the pots set at the
    11 o'clock position and using an o'scope on TP1 (Gecko, please install wire loops there!) and triggering off of the dir signal we can
    see the response on TP1 but in what sequence (P or I or D) pots should be tweaked?
    We have selected the number of encoder pulses per the formula given in the docs for the Gecko G320X drivers.
    Bruce
    May 2012
    32
    Ok, looking at page 2 of this forum I found my answer on sequence to adjust P I D pots.
  1. G320X Tuning
    By emvali in forum Gecko Drives
    Last Post: 02-06-2015, 10:57 PM
  2. G320X Err/Res Current
    By Bob La Londe in forum Gecko Drives
    Last Post: 04-22-2014, 02:27 AM
  3. G320X AND MACH3
    By br1 in forum Gecko Drives
    Last Post: 05-07-2012, 04:25 PM
  4. G320X problems
    By jasko in forum Gecko Drives
    Last Post: 01-15-2010, 05:19 PM
  5. G320X First Revision Manual
    By CoAMarcus in forum Gecko Drives
    Last Post: 08-06-2009, 12:35 AM
