585,557 active members*
3,505 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > To convert Quadrature Encoder signals to Tachogenerator signals
    Feb 2006
    7
    Hi All,
    I am using a DC drive which takes analog tacho signals
    to run a Fanuc DC Motor which only have a Digital
    Encoder , so I need to convert the Encoder signals to
    Analog voltage to use this as Tacho feedback. Can
    anybody help me by suggesting a simple circuit?
    Regards
    Babar
    24220
    Are you using later type Drives? As modern ones run a DC motor in the torque mode, so the tach can be eliminated.
    If you really need a tach, there are several simple dedicated IC's that will produce digital to analogue signal ones I have used in the past is the National LM2907 the IC manufacturers have application sheets on their sites.
    You will only need to use one of the encoder channels i.e. A or B.
    Of course, you will also need the encoder for feedback in a CNC system.
    Al.
    Albert E.
    Jun 2003
    866
    Al, don't the tachos go negative? Seems like you still need both channels to tell what direction you are going in.
    USDigital has a box that does this, it's not particularly cheap.
    24220
    Quote Originally Posted by unterhaus
    Yes :tired: Your right of course, I fired this off in a hurry this morning, and realised it when thinking of it later.
    It requires it more sophisticated DtoA than the national IC.
    I think I have the circuit somewhere , I will try and dig it out tonight.
    Al.
    Albert E.
    Feb 2006
    7
    ACtually this is the main problem , to get the -ve sign. For this I need to have a circuit which can convert the Quadrature Encoder signals to the step and Dir signals , then the Dir signal can be used for changing the sign of the analog output voltage. For Quadrature Encoder to the step and Dir signals I tried the cicuit attached , but it didnot worked, I am getting pulses on the Dir output instead of getting high or low signals....
    Attached Files Attached Files
