585,931 active members*
4,186 visitors online*
Results 1 to 6 of 6
    Apr 2012
    25
    help smoothstepper ethernet!
    I am working on my ss ethernet system. everyone appears to be talking. I keep getting a message that reads "estop not assigned to ss ethernet input" how do i assign it and end this message? thanks-CAM
    Nov 2008
    412
    It does not know to what pin the estop is connected to. If you use mach3 check the pins and ports..
    Forget about global warming...Visualize using your turn signal!
    Apr 2012
    25
    thanks ..that fixed that. i am having some minor problems with things...do mostly to my lack of knowledge.if someone who is familiar with ess going to a win8 setup could pm me id love to be able to call and talk to someone with experience it could save me from going mad!!!!! thanks in advance CAM
    Nov 2008
    412
    sorry, have no idea how it is setup in win8. My cnc is run by xp..
    Apr 2012
    25
    I get a message ft write server no set up?
    Feb 2010
    I doubt I could lend any guidance because it worked for me without any fussing that I can recall but eSS with Mach3 on Win8 definitely works.
  1. DMM Drives and SmoothStepper Ethernet
    By vertcnc in forum Dmm Technology
    Last Post: 03-09-2013, 03:53 PM
  2. Ethernet Smoothstepper with encoders
    By nicubila in forum SmoothStepper Motion Control
    Last Post: 12-11-2012, 11:45 AM
  3. Smoothstepper (ethernet)
    By t300 in forum Novakon
    Last Post: 09-08-2012, 02:43 AM
  4. Ethernet Smoothstepper Windows Firewall Settings
    By surfmachine in forum SmoothStepper Motion Control
    Last Post: 07-21-2012, 06:37 AM
  5. Mach3 Plugin for Ethernet Smoothstepper
    By dwilson26 in forum SmoothStepper Motion Control
    Last Post: 01-31-2012, 07:35 PM
