585,591 active members*
2,860 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Ez Trak SX - "No Cable" Error Message
    Apr 2013
    16
    I am getting a "No Cable" error message whenever I power on. I have checked every single connection between the circuit board where the cable runs out of the back of the machine to its final destination inside the monitor and it all checked out fine. I've made sure all my wires were tightened down all the way, and I've checked every other connection I can think to check. Does anyone have any suggestions as to where I should go from here?
    Jun 2007
    129
    Looks like you have a problem with your monitor or the video output of the mother board. The first procedure would be to plug in another vga computer monitor. If that works, you need another monitor.
    IMO, odds are this is a mother board problem and the VGA output. When these types things happen, it is a good idea to check the output of the power supply to the mother board. It might be the PSU and easy to replace.
    Apr 2013
    16
    You were right, it's the PSU, thanks for the help.
    Jun 2007
    129
    Glad I could be of help because I really appreciate all the help that is available on this forum.
  1. "master encoder state error" AB ultra100 error message
    By ShapeShaver in forum Servo Motors / Drives
    Last Post: 07-31-2013, 04:09 PM
  2. Replies: 2
    Last Post: 02-17-2013, 02:49 PM
  3. Desperate for help. Roland CJ-60 "Capping Error Message"
    By jmmccann in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 12-03-2011, 07:01 PM
  4. Bridgeport EZ-Trak Replacement Monitor "New Color LCD"
    By RADAPG1 in forum News Announcements
    Last Post: 05-22-2011, 04:32 PM
  5. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
