585,992 active members*
5,588 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Southbend Magnaturn 612, from grave to production!
Results 1 to 14 of 14
    Jun 2012
    125
    This will hopefully help some one out. MPM Inc. currently has 2 Southbend Magnaturn 612 lathes. It is my job to get them running. They were on wooden pallets with parts here and there. The PC that is suppose to run them is non functioning.
    I think there are a few Magnaturn 612 Owners here that can offer some help.
    David
    South Bend MagnaTurn 612
    Jun 2012
    125
    David thank you for responding I have these for screens and tried 2 difefernt versions of software. https://plus.google.com/photos/10704...31676303238433 I still cant get an communication to the lathe.
    Jun 2012
    125
    So it looks like the secret is to turn on the main power to the lathe then after the cooling fans are up to speed power up the lathe. I have also had the old drives run through a recovery program to get everything back and bootable. Now I can tun this thing on and it works like a champ. I still have not made any parts with it yet but dont feel that will be an issue.
    Jun 2012
    125
    SouthBend has the following:
    PSBCNC3136 Assembly and Parts Drawings manual $40.00
    PSBCNC2085 Owners Manual for Magnaturn CNC lathe $66.00
    email us at [email protected] or call our parts dept. at 417-886-2954
    Jun 2012
    125
    Jun 2012
    125
    Needs a computer with an 8-bit ISA slot ISA in Vintage Computing | eBay
    Jun 2012
    125
    Good to see you have it working.
    What tooling do you have for the machine?
    I have Valenite ISO Screw Down Tooling.
    I think South Bend Had Valenite make some custom length toolholders for the 612
    Post some pictures of your first part!
    David
    South Bend MagnaTurn 612: 612 MagnaTurn CNC Lathe
    Did you buy the factory manuals, did you think they were the $$
    David
    Jun 2012
    125
    Tooling I have 4 tools that is what it came with. I did buy manuals from Grizzly not really work the price but now I have them. The operation manual is kind of a must have.
    Thanks for the update, I have the Assembly and Parts Drawings manual, and a version of the operations manual, but I think mine was for a prior version of the software. So have you made any parts yet?
    David
    Jun 2012
    125
    No parts, no time
    Mar 2007
    89
    parts manual or part number
    Quote Originally Posted by David C. Allen View Post
    David
    David, may I purchase a copy of the parts manual from you? If not, can you give me a part number so I can try to get a part from South Bend?
    I called South Bend today. They said my lathe is too old. They have no manuals and I can try to order parts if I have a part number.
    My lathe is a CNC Magnaturn 612 serial number 00022 SL. I need the motor gear that spins the turret.
    thanks if you get this.
    Stuart
  1. art grave 2008
    By Diego in forum Spanish
    Last Post: 03-23-2012, 02:45 AM
  2. southbend magnaturn 612
    By cidteach in forum Mini Lathe
    Last Post: 01-15-2011, 11:13 PM
  3. Help with identifiyng Southbend Magnaturn
    By hrhoward in forum Uncategorised MetalWorking Machines
    Last Post: 01-15-2011, 11:09 PM
  4. Southbend Lathes
    By cmnewcomer in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2009, 09:53 AM
  5. Another BOSS Back from the grave!
    By sbalder in forum Bridgeport / Hardinge Mills
    Last Post: 07-06-2006, 03:06 PM
