I think the adaptor you have takes a 'straight through' type cable and set the pins for null modem use together with hardware handshake signals,
You will need a null modem cable for the Siemens so the adaptor should work.
This link explains the conections a bit more in detail.
http://www.cadem.com/ncnet/dnc-detai...merik-802d.pdf
With full handshake usually all the handshake connections are made across the cable, with no handshake they are usually jumpered out inside the connector.
Al.
Albert E.
