I have one of these round column mills that I converted to CNC (stepper motors) a while back. I drive the z axis through the existing mechanism and have the backlash down to about 0.020. I find this to be unacceptable as it seems to break a lot of the smaller end mills if I push it too hard. I have seen several references in the forum that the quill spring should be reversed. I thought I would give it a try before going to ball screw z axis drive, however, when I took the spring casing off, I find a pretty hefty 1" wide spring tightly wrapped in there. I'm looking for hints as to how to unwind it out of there and more so how to get it wound back in, in reverse. Can anyone share their experience doing this and is there a purpose built tool or gadget anyone has used to accomplish this? Thanks in advance.
