585,975 active members*
4,957 visitors online*
    Dec 2012
    12
    Cutting Corian
    Very green here and till learning a lot about my machine (Joes 4x4 Hybrid) and cutting. One of the materials I want to work with is Corain to make molds out of.
    I did my first cut a couple days ago. The stock was 4" x 15" x 1/2". I machined about 1/8" off one side only while also cutting in an airfoil shape for a model airplane horizontal stabilizer. I used 1/4 end mills, both flat and radiused with the Hitachi router set at "3" cutting at 70 ipm.
    When I took the finished part off the machine it has a noticeable "warp". That is it no longer lays flat on my table. The two ends are each up close to 1/16".
    Anyone with Corian cutting experience give me some ideas as to what I can do differently to avoid this happening or get rid of the warp?
    Thanks, Rick
    Dec 2018
    Put it in the oven at 325 for a while then set or clamp to a flat surface
  1. Bonding Corian to Corian. What to use?
    By mcphill in forum Composites, Exotic Metals etc
    Last Post: 08-16-2016, 08:54 AM
  2. Cutting Corian Router Templates
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 09-24-2012, 10:56 AM
  3. SuperPID Cutting Corian
    Last Post: 06-26-2012, 05:35 PM
  4. waterjet cutting corian
    By seawolf217 in forum Waterjet General Topics
    Last Post: 11-20-2009, 06:17 AM
  5. Corian Laser Cutting
    By abdmalki in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2008, 12:30 PM
