585,886 active members*
5,582 visitors online*
    Mar 2010
    19
    Freezing aluminum honeycomb core
    Does anyone know what solution other than water is used to cut honeycomb core? We can't use wax do to contamination of the core. I heard on emastercam that there is a slime solution used in the core cutting industry but couldn't remember the name of it. We have to hold pretty tight tolerances and can't have the cells fold over.
    Thanks in advance
    JBerger
    Apr 2007
    23
    If it is uncompressed a band saw dry is fine. If open use a long snap type retractable blade and hold the core between a template of what shape you require it is very clean and will not fold the edge of the core. Blade must be new and will need to be snapped off after a few cuts. You will also be able to cut a bevel at 45 deg with open core this way.
  1. Honeycomb, Knife or Pin
    By OSLaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-07-2012, 10:36 PM
  2. Machining Nomex Honeycomb Core
    By RMM97502 in forum Material Machining Solutions
    Last Post: 12-22-2010, 06:12 PM
  3. Is there any way to clean PETG residue off Aluminum Honeycomb
    By FlyGuy007 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-26-2009, 11:24 AM
  4. Machining aluminum honeycomb
    By Making chips in forum Composites, Exotic Metals etc
    Last Post: 06-03-2008, 05:23 PM
  5. Alum Honeycomb core
    By cncadmin in forum Community Club House
    Last Post: 06-12-2005, 05:26 AM
