585,883 active members*
4,531 visitors online*
Results 1 to 10 of 10
    Dec 2007
    13
    Writing time into file...Siemens 840d
    Hello
    I know how can i get one cycle time one part and i want to write the value into e.g program or some file. Is it possible?
    Nov 2011
    40
    Hi kotlas6667
    Can you explain more in detail what are you trying to do i think i might be able to help you
    Dec 2007
    13
    Hi
    My machine is connected to net and include hdd where i can conect e.g on F:\ (\\xxx.xxx.xxx.xxx\$f)
    Is possible or is it somewhere (in HDD) the registered value of the R parameters?
    Dec 2007
    13
    Quote Originally Posted by IfeCro View Post
    Hi kotlas6667
    Hi
    Nov 2011
    40
    Yes it is possible.
    I am not sure if you can write on network location, but you can do that in your WPD or SPF or MPF directory on the machine.
    You can do that with WRITE command.
    I am using it to write my probing results into file "PROBE_RESULTS.SPF".
    Now you should do the same thing, but you will have to create your own cycle/macro with timer function and WRITE instructions of course.
    Then you call that cycle on beginning and end of your program with different parameter for ON/OFF
    Example:
    T1 D1
    M6
    TIMER(1) ;1 turns your timer ON
    G75 Z0
    TIMER(0) ;0 turns your timer OFF
    M30
    So i would do it like that if it was me.
    Dec 2007
    13
    Yes it is possible.
    Example:
    T1 D1
    M6
    G75 Z0
    M30
    HM....
    1.how can i create own cycle?
    2.what will include (TIMER(1)) cycle?
    3.how do you write values into "PROBE_RESULTS.SPF"?
    Nov 2011
    40
    That custom cycle writes the values by it self into my result file
    But if you never wrote any of your own cycles i think you might be in trouble.
    I am not sure if i can explain everything in details here.
    Contact me on PM and give me your e-mail we will discus some details and maybe later on this week i write you that cycle.
    Cheers
    Dec 2007
    13
    Hi all!
    Writing is fine, but when writing the file is always loaded (mark X), and I want to this file after writing unloaded (without X). is it possible?
    Apr 2002
    5003
    Try downloading this file.
    Siemens Industry Online Support - Automation Service, Automation Support, Simatic Service, Simatic Support, Technical Support, Technical Consulting
    All of the functions with writing, reading parametres, math are listed there.
    May 2004
    97
    Re: Writing time into file...Siemens 840d
    Quote Originally Posted by kotlas6667 View Post
    Hi all!
    Hi there - did you ever find a solution to unload a Siemens program automatically?
  1. Need Siemens 840D Help
    By gears2010 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 07-25-2013, 03:54 PM
  2. SIEMENS 840D
    By BKCOM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-08-2010, 11:21 PM
  3. Probing with Siemens 840D
    By tjseza in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 11-24-2010, 05:29 AM
  4. Looking for some Siemens 840D work?
    By Irvingw in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 02-11-2010, 08:31 PM
  5. VB & Siemens 840D
    By Thunder in forum Visual Basic
    Last Post: 09-22-2007, 04:28 PM
