585,996 active members*
4,856 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Subprogramming/Subroutine issue...Please help!
    Mar 2011
    38
    Hey guys. I hope I have the correct forum for this question.
    I have three complete and running programs. I want to combine these into one large program.
    It needs to run like this:
    Program #1
    Program #2
    Program #2
    Program #2
    Program #3
    Any ideas on how I can accomplish this without using gobs of memory? Copying and pasting the three different programs into the configuration it needs to go above does not interest me when I know there is a better, more effective solution.
    Any help would be greatly appreciated! I know that some sort of subprogram/subroutine call out could be used...just not sure of the "rules" to abide to in this case. I'm also generating the NC code with CAM software for all of the programs mentioned above, so the less modification I have to do with the post, the better.
    I have a old 4020 machine with CNC88 controller...Format 2.
    Thanks!
    Jul 2009
    317
    01*MAIN PROGRAM
    G0G90S1200M3X0Y0E1
    1)0M98P2L1
    2)M98P3L1
    3)M98P4L1
    4)M2
    line 1 calls prog #1 once
    line 2 calls prog #2 once
    so and so.
    At the end of each sub program instead of M2, insert M99 it will go back to Prog#1 and execute the next line (program)
    At end of Prog #1 insert M2.
    Mar 2011
    38
    Hmm...I'm not sure about that one....nor even fully understand what you just said.
    My thoughts would have it go like this:
    L100
    <Insert Program #1 here>
    M17
    L200
    <Insert Program #2 here>
    M17
    L300
    <Insert Program #3 here>
    M17
    M30
    Then proceed with...
    L101
    L203
    L301
    M99
    Is this correct thinking??
    May 2005
    53
    Both are correct. The first example is format 2, and the second example is format 1. The first example will run in format 1 or 2, but I'm not so sure about example 2 runinnig in format 2.
    Whew! That was alot of explaining. I need more coffee!
    Jim
  1. Subprogramming
    By gordo.hogan in forum FeatureCAM CAD/CAM
    Last Post: 08-01-2012, 02:55 PM
  2. Subprogramming with Acramatic 2100
    By dmitriy in forum Cincinnati CNC
    Last Post: 07-31-2011, 09:25 AM
  3. fanuc subprogramming
    By warren01 in forum G-Code Programing
    Last Post: 12-25-2010, 01:07 AM
  4. Subprogramming
    By hitachi in forum Uncategorised CAM Discussion
    Last Post: 06-17-2006, 03:09 PM
