585,690 active members*
4,822 visitors online*
Results 1 to 7 of 7
    Mar 2007
    29
    220V in to Huanyang Inverter
    Just got my 2.2 kw Huanyang inverter and spindle. Referring to the manual R, S, T are the power input terminals, but it doesn't say which get the hots or neutrals. Can help but think it matters...don't want to let any smoke out of the inverter.
    Anyone have any guidance?
    24220
    If you look at the 'Wonderfull' Huanyang manual, it shows any two phases can be used for 1ph input R,S or T, you do not connect a neutral, if you happened to inadvertently do so it would not cause any concern as the neutral would be reverse biased by the 3 phase bridge on the RST input.
    Al.
    Albert E.
    Mar 2007
    29
    I'm looking at the manual ...it says
    RST INPUT CURRENT IF THE SINGLE-PHASE SOURCE MEETS TWO WILLINGLY
    And on another page
    THE POWER SOURCE IS PUT INTO THROUGH THE R.S.T TERMINALS. THE 220 CAN CONNECT WILLINGLY TWO PHASE R.S.T
    So ill only have two connections...one of the R.S.T trio is going to be vacant?
    24220
    It sounds like you have a different manual? The Chinglish version?
    Mine suggest pick any two, the 3rd left unconnected ( make sure you do it willingly!).
    Al.
    Albert E.
    Mar 2007
    29
    "Pick any two"; Now that I understand...even when you say it in Canadian.
    Funny though, the diagram shows three fused lines going to each R.S.T. and that's what had me baffled.
    Jerry in Maine are thanking you willingly for each info of you have provided to him happily.
    Jan 2007
    723
    Quote Originally Posted by Jerry In Maine View Post
    I love your chinglish!
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Aug 2011
    107
    Sounds more like Yoda..
    "Wire your VFD you will"
  1. Huanyang VFD Inverter all available Error Codes
    By Saintstone in forum Phase Converters
    Last Post: 07-08-2017, 11:26 AM
  2. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  3. Huanyang Inverter Problem
    By icanoe in forum Community Club House
    Last Post: 03-15-2013, 01:35 PM
  4. huanyang inverter burn
    By edgas10 in forum CNC Machine Related Electronics
    Last Post: 07-02-2012, 06:42 PM
  5. Huanyang inverter
    By mdileva in forum Phase Converters
    Last Post: 06-18-2012, 03:24 PM
