585,760 active members*
3,964 visitors online*
IndustryArena Forum > CAM Software > EZ-CAM Solutions > Posting Metric Program to BP Boss6 - Post Available?
    Apr 2012
    A friend tried to post for me a program from a metric DXF print file to a BP S2 Boss6. When we went to the folder with all of the posts there was a Boss6I file listed but no Boss6M file listed. Based on all of the other 'I' & 'M' posts listed in the folder there should have been a Boss6M file, or so we believe.
    Does EZCAM have a Boss6M post that somehow got deleted? Does the Boss6 convert Inch to Metric internally using the Boss6I post? I forgot to ask him which version of EZCam he has but his last update was to XP and was at least 5-6 years ago so if that makes a difference I will check with him.
    I apologized for my ignorant question, I just got the mill and am looking for an easier way to program the Boss6. It is my first CNC mill.
    Any and all help would be much appreciated. TIA!
    Bill
    Mar 2004
    69
    You can post a metric part with an inch post and run the machine in inch.
    J.
    May 2013
    22
    Thank you for the reply.
    Sent from my iPad using Tapatalk HD
    May 2006
    57
    Bill,
    All upgrades come with a new library of post processors. If a post is not in the library, for some reason, usually a post is modified the same day you upgrade.
    Dec 2012
    395
    Hi Bill,
    There are EZCAM BP-Boss6 Inch and Metric postprocessors.
    Do you have the MBuild program to modify the postprocessor ?
    Regards,
    Heavy_Metal.
    Attached Files Attached Files
  1. Ez-mill 8 posting program for Haas
    By Shaun Smth in forum EZ-CAM Solutions
    Last Post: 01-24-2013, 09:57 PM
  2. Posting Question: English to Metric
    By seijack in forum Mastercam
    Last Post: 08-03-2012, 10:38 PM
  3. Need HELP posting handwitten program
    By keystone76 in forum Fanuc
    Last Post: 01-07-2012, 07:26 AM
  4. G76 Metric Program
    By rylanrouge in forum Okuma
    Last Post: 04-06-2011, 10:25 PM
  5. MasterCam BOSS6 Post
    By btcoutermash in forum Bridgeport / Hardinge Mills
    Last Post: 06-24-2009, 03:17 AM
