585,556 active members*
3,391 visitors online*
Page 1 of 2 12
Results 1 to 20 of 29
    Apr 2013
    18
    My first T-slot CNC router
    The design of my first T-slot CNC router. Just received the laser cut parts. Expecting the rest of the machined parts next week. Cannot wait to start assembly! Comments welcome!
    Oct 2009
    78
    JCvdW,
    Nice CAD drawings. I would suggest that you use a single motor in place of the two on what I assume to be Y axis. If one motor fails or looses steps then the surviving motor is going to put your framework in a potentially damaging bind.
    RFB
    Excellent, looks like you will be having fun and making great things with your new machine.
    Tweakie.
    CNC is only limited by our imagination.
    Apr 2011
    Great design!. As RFB suggested, instead of two motors for the Y axis use only one, either in the center of the frame to equilibrate the force applied, or on one side the motor and put a belt to the other nut.
    Sorry for my english.
    Apr 2013
    18
    Quote Originally Posted by traxxxto View Post
    Thanks for the comments!
    I took my idea for two stepper motors from a commercial German design: CNC Fräsmaschinen und Graviermaschinen, CNC fräsen für Profis und Hobby Fräse CNC Technik. I would appreciate feedback of experience with these machines...
    Apr 2005
    253
    I'd stick with two motors, loads of builds here using two with no problems and it will ensure no racking during normal operation, sure you can tied then will belts and pulleys if you wanted but i'd run it as is.
    Loading forward to watching your build.
    I'll get it finished sometime after I start it.....
    Apr 2013
    18
    Partial assembly to check that everything fits
    Just received the squared T-slot extrusions and rail supports from the machine shop. Attached some pictures of the first partial assembly to check that everything fits. Surprisingly rail alignment was spot on first time. The frame is solid and sturdy. Still waiting for motor mounts and ball nut blocks to arrive from machine shop.
    Attached Thumbnails Attached Thumbnails IMG_20130421_205611.jpg   IMG_20130421_180417.jpg
    Apr 2013
    18
    Everything together for the first time
    Had to straighten one of the Chinese ball screws that was bent during shipping. Still have to deal with two small dents on the 20mm ball screws that got damaged during shipping. Have to decide on where to mount the limit switches and then re-assemble the whole machine will lock-tite on all the bolts. Should have it up and running within a week. Must also still design and build a proper base on wheels.
    Attached Thumbnails Attached Thumbnails IMG_20130425_223453.jpg   IMG_20130425_223655.jpg
    Apr 2013
    18
    All three axes under computer control!
    First time with all three axes being controlled by LinuxCnc. Fortunately no need to use the emergency stop (yet!). Disappointed that one of the Chinese flexible couplers have been drilled skew! Still have to connect limit switches and fire up the spindle. Finally ready to reassemble with thread lock on all the bolts and measure the accuracy and repeatability of the machine.
    Apr 2013
    18
    It works!
    Chai from items in linearmotionbearings store on eBay! kindly offered to replace the skew flexible coupler free of charge!
    First routing of a piece of foam - using the default demo g-code that comes with LinuxCnc. Very pleased with the result!
    Now to find suitable CAM software and learn how to generate G-code. The aim is to do some 3d modeling of chess pieces.
    Mar 2012
    276
    Quote Originally Posted by JCvdW View Post
    Vectric makes some of the best CAM programs there is. In the downloads section you can get trials of their software. Try Cut3D and Cut2D and do the tutorials.
    If you use irc, irc.freenode.net #linuxcnc is where a large group of us LinuxCNC users hang out.
    My CNC Router Build - http://tinyurl.com/c3vs3ca
    May 2013
    Apr 2013
    18
    Quote Originally Posted by r00t4rd3d View Post
    Thanks for the suggestion. I am also considering DeskProto. Their pricing for hobbyists is quite reasonable.
    Aug 2011
    999
    ...........I am also considering DeskProto............
    Deskproto has excellent features and if you want to do rotary machining or use waterline path strategies there is not much else out there for a reasonable price.
    However....it is a bit difficult to use, has a zillion parameters and even more opportunities to screw up. Complex surfaces may take a VERY long time to process. I use it when I have to but for most simple jobs I prefer Vectric Cut3D. I can get from a 3-D model to g-code in a fraction of the time compared to DeskProto.
    Apr 2013
    18
    Quote Originally Posted by JerryBurks View Post
    Thanks for the good feedback. The picture shows a first attempt at a Blender model of a chess knight that I want to machine out of hard wood. Would Cut3D be suitable for something like this, or would I need Deskproto?
    Aug 2011
    999
    Nice model! How big is the resulting figure supposed to be?
    If it is regular chess set size, the detail features will be a big challenge. You would need a very fine tip ballnose and very long machining time.
    It can probably be done with Cut3d 4-sided machining but precise re-clamping very difficult. Also, Cut3d can only raster scan the surface for the finish cut, probably not an optimal strategy.
    To machine this properly I believe a rotary axis would work best in continuous rotary mode. Segmented rotary machining may leave steps between the surfaces machined from various sides. Anyway, DeskProto may be better.
    I purchase a chess set 3-d model from Turbosquid last year which is not even as detailed as yours. But I lost patience after 8 or 10 attempts to machine the king with various misconfigurations and other errors. Got to try that again sometimes. Here a toolpath made in DeskProto:
    May 2013
    Apr 2013
    18
    LinuxCnc vs Mach3
    Using LinuxCnc to get the machine up and running made me realize very quickly that unless you are a Linux expert, this is not the way to go. Could not get the USB ports on the PC to work, and therefor could not load my own G-code file!
    Started playing with Mach3. It was equally easy to configure, and I had it up in running within a few hours. Mach3 is in another class with good documentation and on-line tutorials! The first G-code generated with DeskProto transferred seamlessly to Mach3.
    Mar 2012
    276
    None of your usb ports worked when you tried LinuxCNC, not even for keyboard or mouse?
    LinuxCNC also has more documentation then most people will ever need: http://linuxcnc.org/docs/html/
    Apr 2013
    18
    Chess knight - first attempt in foam
    I am sure it is finger trouble on my side. I may have switched off all the USB ports in the BIOS at some point in an attempt to get the parallel port jitter as low as possible. But I must admit, with the results I am getting with Mach3 and DeskProto, I do not even feel like going back to Linux and fault find further.
    Attached is a picture of the first attempt with the chess knight modeled in Blender. It took about 30 minutes to machine out of foam using standard Dremel bits that I had. It looks promising!
Page 1 of 2 12
  1. Just another CNC router from T-slot aluminum
    By pilotarix in forum T-Slot CNC building
    Last Post: 02-05-2013, 07:19 PM
  2. one slot is coded other slot is not there
    By cwaugs in forum Uncategorised CAM Discussion
    Last Post: 05-06-2011, 03:00 AM
  3. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  4. T-slot Router Bed Extrusion
    By gotswrv in forum Want To Buy...Need help!
    Last Post: 07-11-2008, 02:16 AM
  5. Replies: 7
    Last Post: 04-12-2007, 03:00 AM
