Hello. I have a problem with my lathe. It shows E.214 on the drives and next to them writes L1. I found that this error is short-circuit. Can you help me fix it? Thank you.
bump
The drive's model is MCS-20L
Input: 3 X 220 VAC / 50-60 Hz
Weight: 3.8Kg
CTRD-L: 05C, POT-L: 03C, OPR: 00A, VAR: 00A, SOFT: M203A21, MOT:02
lo: 10 Amp
lmax: 20 Amp
Hello. I have a problem with my lathe. It shows E.214 on the drive axic x ,and I found that this error is in
center board RF driver IGBT . Can you help me fix it? Thank you.
