585,997 active members*
5,068 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Compiling mxt-file
    Oct 2011
    4
    Compiling mxt-file
    Hello,
    i´ve got a mxt-file and changed the default from inch to metric.
    Now i would like to compile it and generate a mcp-file (Edgecam 2013R1).
    Can anybody tell me how to do this ?
    I do not have the cgd-file.
    Thank you ...
    Jun 2012
    edit---transform----scalexyz input 25.4 enlarge 25.4 ok
    Jun 2008
    125
    Hi Daudi,
    Compiling a mxt file is easy, if you've got the right license.
    Open your cls, and check whether you've got the 'Code Generator Compiler' licence available.
    If so then just go to All Programs > Edgecam 2013r1 > Programs > Code Generator. Load in your mxt and hit compile.
    If you haven't got that license then either attach your mxt file here or DM me and I'll compile it for you and send it back.
    Mar 2007
    53
    Hi Daudi,
    If your .mxt file is a few years old - I recommend you start a new .cgd post.
    the post processor controls the cycles, functions and menus that are available
    in Manufacture Mode. without an adaptive .cgd file you can never update your
    post with a new template, so you will never see the new waveform roughing cycle or the
    have the ability to select "Use Current Stock" - "Update Stock".
    and a lot of other improvements that are all dependant on the post.
    Making a new post really isn't that difficult.
    To the best of my knowledge the post "Masters" at Edgecam stopped
    writing / editing / compiling .mxt files years ago.
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. Call file as variable from within a file
    By CaptainVee in forum LinuxCNC (formerly EMC2)
    Last Post: 12-29-2012, 08:23 PM
  3. Converting a pdf file to UG part file
    By gaoxingdcf in forum UG NX
    Last Post: 05-20-2010, 01:47 AM
  4. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  5. Compiling G Code
    By logansams in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-07-2009, 05:49 PM
