585,602 active members*
3,479 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Running g-code on a proto-trak m3 controller
    Dec 2007
    123
    I am wanting to patch into a proto-trak m3 controller and run g-gode from my CAM software. I did a search and found one comment from a member patching into the RS 232 port with an outboard computer. Unfortunately his details were a little thin, and I get an error when I try to private message him.
    Anybody else doing this? Please share some details about the setup, software, and your experience.
    Thank you.
    Feb 2007
    664
    did you try a null modem cable?
    Dec 2007
    123
    No, we haven't tried anything yet. We just started exploring the process. I am looking for more info, setup, software, etc. Hopefully someone is doing this setup and is willing to share enough info for us to get started. Additionally, I am wondering if we can spool from a laptop and run bigger files than the proto-trak can run (740k memory max)
    I have a cnc router running with deskCNC, and like proto-trak, it is limiting. So I do all my programming in more sophisticated CAM software. Standing at the proto-trak and taking 4 times as long to program, and not being able to program the next file while it is running is a huge waste of time. Fortunately deskCNC is running on an XP machine and I can just download g-code with a thumb drive. It would be awesome to have a laptop connected to the proto-trak and spool the g-code. Proto-trak won't let you ramp into a pocket, do raster cutting, surface contours and lots of other things that even simple CAM software has as features. Heck, it would be faster to just write the program in g-code with notepad. But first we have to understand how to get into and out of the controller.
  1. Proto Trak Plus
    By seapacer2 in forum Bridgeport / Hardinge Mills
    Last Post: 06-19-2018, 03:43 PM
  2. Proto Trak MX2
    By mess1207 in forum Uncategorised MetalWorking Machines
    Last Post: 04-06-2015, 06:02 AM
  3. PROTO-TRAK
    By Gary55Ford in forum MetalWork Discussion
    Last Post: 01-24-2012, 02:40 PM
  4. Proto Trak M3
    By ToolBreaker in forum DNC Problems and Solutions
    Last Post: 04-09-2010, 06:03 PM
  5. PROTO-TRAK
    By Gary55Ford in forum Fanuc
    Last Post: 01-26-2008, 01:47 AM
