585,735 active members*
4,951 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > alarm: 815375 turret turning not locked
    Oct 2012
    24
    hi good day
    i have a problem with our machine Index G200. It happened after battery failure in CSB(siemens 840c) card. well i manage to install all machine data and it successful. but the only problem is Turret 2 ,when initialize for position, it rotates but when it stop it does lock.. we dont know what happened, well it seems the turret 1 no problem at all. and why this turret 2 does work as the same with turret 1..did we miss some parameters? or data ?. thanks hope someone had an experienced with this problem share it ...
    Oct 2012
    24
    sorry for bothering this forum. but i got the problem , just loading some param in m19 offset S1 and S2, well thats it .. if some one encounter this problem dont hesitate to ask maybe i could help..
  1. servo turret alarm
    By Hifeed in forum Fanuc
    Last Post: 05-01-2020, 01:22 AM
  2. moriseiki sl-203 ??turret alarm??
    By j_c1987 in forum Mori Seiki lathes
    Last Post: 12-01-2012, 02:52 AM
  3. HELP QT 350 alarm code 371 turret servo alarm
    By kirkmach in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-19-2011, 09:39 AM
  4. AL-51 Turret amp alarm
    By Tony1980 in forum Tutorials
    Last Post: 05-06-2011, 03:49 AM
  5. Tool Turret Fault Alarm on TL-1 with no Turret?
    By Edster in forum Haas Lathes
    Last Post: 02-08-2010, 03:35 PM
