Hi
My name is Vagelis and I am from Greece
I would like your advice and your opinion on the plans below.
Involving a cnc (1500mm x 1000mm) which
will runs with Yaskawa servo 400 watt (ordered and is on its way)
Supported drivers 20mm, ballscrews 16mm
Spindle 2,2 KW water cooled (I already have )
Now I am working on drafts of the skeleton
After reading a lot and saw a lot more I finally decided to use steel for chassis bridge, and restrict the use of aluminum only in Z (to become lighter)
Beyond that, as you'll see in the picture the long axis (Y) will have a length slightly less than 1500mm and the supported drivers will be screwd on I beam 120X60 mm
The two (right and left) will be joined by a plate of steel 10mm. To make the joints and set out distortions , each beam will be welded to a steel plate (blue in photo) with 6 holes (drilled oval) for fine adjustments.X axis (on which it moves Z) will put a rectangular beam 120X60 4 mm, which will be joined to the ends of the bridge in a corresponding manner. I would like your opinion mainly for this axis. As you can see at the photos the two supported rails drivers of X axes are not at the same plane , one "sees" in front and the other upwards. This gives me the ability to adjust the squareness of the spindle to the table.
Drivers in Z have distance (from center axis Khandro shaft about 175 mm) is it too;
Finally I would like your comment regarding a post I saw on cnc zone, where someone claimed that the weight (which most are trying to reduce as much as possible) finally is not an "enemy." He supports that the weight offers stability, reducing vibration and resonance as well as the fact that the tendency to fill the holes with machinery and cuttings to the ease finally beyond the aesthetic piece and do not offer anything substantial, however many times the " Slightly "works against robustness.
I would like to say to those who volunteered their opinion to remind them that the motors ( Yaskawa servo 400 watt ) have plenty ofo power for such a construction (I think), so any little excess weight not think to bring disaster.
Thank you for your time
Sorry for my bad english
I expect your advice
Vangelis
