THE G320X MANUAL SAYS
CURRENT LIMIT
The current LIMIT trimpot sets maximum continuous current the motor is permitted to have. It is adjustable from 0 amps to 20 amps. The trimpot setting is proportional to current; if it is set to full scale it will be outputting 20A, half scale will output 10A, quarter scale will output 5A, and so on. The behavior of the trimpot is controlled by DIP SW 10. If SW 10 is on (default), the G320X will limit the current to the trimpot setting until it runs into an excessive load. It will then start a 1 second timer and limit the current draw to 20A; if it does not overcome the load it will limit at the trimpot set current. The load must drop below the trimpot setting to reset the timer. If SW 10 is off (G320 compatibility mode), the G320X will constantly output what the LIMIT trimpot is set to. Normally the LIMIT trimpot is set to the motor’s continuous rated current.
I HAVE A QUESTION, SW1O SHOULD BE SW7?
SW7 TORQ
SW7 “OFF” = Use
LIMIT trimpot setting only (default)
SW7 “ON” = Allow 20A for 1 second, then use LIMIT trimpot setting
