585,975 active members*
4,605 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Xilog 3 Parametric Programming Offline Programming
    Jan 2006
    28
    Red face Xilog 3 Parametric Programming Offline Programming
    In the shop I work at we have a Morbidelli Author 600 and Xilog 3. We have BobCAD CAM trial version which currently generates basic G-Code for Xilog Plus Morbidelli Type of machine. Now this is the first time we want to create a program in BobCAD Cam to sent to this machine. How do we go about and create the G-Code and import into the Xilog 3 software. I have tried the .XXL format and the .CNC format with now luck. Is there a standard of G-Code writing which I do not know of?! I have program basic program directly in the Xilog 3 and know the conventions that they are require of the software to be read, however am I missing something?! Many thanks for any help provided.
    Julio Cruz
    [email protected]
    (919) 714-2103
    You should have a program to convert the .xxl files into .pgm files. I think it's called winXiso, but I'm not positive. I can't check until Monday when I go back to work.
  1. Xilog Plus Programming Manual
    By bmstu in forum Commercial CNC Wood Routers
    Last Post: 11-22-2022, 03:07 PM
  2. Parametric Programming
    By gene rhodes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-30-2010, 12:34 AM
  3. New to Parametric Programming
    By weaston in forum G-Code Programing
    Last Post: 02-27-2007, 02:40 PM
  4. Parametric Programming
    By weaston in forum Uncategorised CAM Discussion
    Last Post: 02-20-2007, 02:25 PM
  5. Parametric Programming
    By widgitmaster in forum BobCad-Cam
    Last Post: 05-04-2006, 07:04 PM
