585,589 active members*
3,572 visitors online*
IndustryArena Forum > CAM Software > CamBam > compensation G41 and G42
    Apr 2013
    4
    Hello,
    I just installed version of CamBam 0.9.8L.
    It creates the path of the tool center, regardless of compensation G41 and G42.
    I tried to post pro Mach3 and Mach3-CV.
    How can I do? Thank you.
    Dec 2008
    292
    If you are using Profile or Pocket MOPs, CamBam calculates tool path taking the tool diameter into account. If you left the tool diameter at zero in your MOP, CamBam will calculate the tool path on the center of the line/path you have drawn for a Profile MOP. Or, if you used the Engrave MOP, CamBam will calculate the toolpath centered on the line you are engraving.
    Don
    Apr 2013
    4
    thank you for this answer.
    CamBam does not manages the G41 and G42
  1. compensation G41 and G42
    By Guillaume89 in forum CamBam
    Last Post: 04-28-2013, 07:12 PM
  2. CRC compensation
    By hartan in forum GibbsCAM
    Last Post: 11-09-2010, 10:46 PM
  3. XY Angle compensation ?
    By rdpdo in forum CamSoft Products
    Last Post: 06-25-2010, 11:12 PM
  4. Tool compensation
    By ssozonoff in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-21-2009, 04:06 PM
  5. RAM compensation 15M
    By PTtec in forum Fanuc
    Last Post: 09-25-2008, 10:32 AM
