585,975 active members*
4,340 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > connecting YASKAWA sgdm-04ADA servopack
Results 1 to 1 of 1
    Mar 2013
    15
    Hi guys
    Recently I received a package motors and drivers of Yaskawa and because of inexperience I am trying to find out about the basics of wiring
    I downloaded the manual from which you quote an image which (for which they have been willing to help) you should see, because it is based on my questions which I spend immediately
    Following the path of the current
    1st-The number 1 element is the logical main switch of the electrical panel which reaches the current from the grid. This switch is only one for all three drivers or each driver should have its own switch?
    Then the current goes to the filter and from there passes in number 2 element. What's this?is it leakage current (circuit breaker). From this element the current goes to the driver in the slots L1 and L2. The question is similar to the first. From number 2 item we will connect the current in parallel to the three drivers or any driver I want a separate switch . In my electrical panel should I have for all the three drivers total 1 or 3 elements with the number 1 and 2 of the image
    To pass to the next question I must say that my cnc would use as controler a PC in which mach3 will be running. The parallel port of the pc will connect to the breakoutboard
    Third question
    Where I should connect the breakoutboard ? In port 3 or 4. The manual shows a computer connected to port 3, but maybe thiw port is for the computer that will set the driver and not for the computer that run mack3. What, therefore, the manual describes as "host controler" is it the computer that runs the mach3 (so i should connect the breakoutboard to port 4)
    Anyone who has the knowledge the mood and the time can help
    Thank you very much for your time
    Vangelis
  1. Yaskawa SGDM fault help needed
    By tommee10533 in forum Servo Motors / Drives
    Last Post: 05-06-2017, 08:37 PM
  2. Help with Yaskawa SGDM-04ADA-V ac servo drives
    By geebow in forum Servo Motors / Drives
    Last Post: 12-13-2015, 05:09 PM
  3. Yaskawa SGDM cannot run over 400 RPM!!
    By danielm in forum Servo Motors / Drives
    Last Post: 04-11-2012, 11:30 PM
  4. Appropiate 24V power supply for Yaskawa SGDM servopack?
    By kbayram in forum CNC Machine Related Electronics
    Last Post: 08-19-2010, 06:22 PM
  5. zero speed problem with servo pack Yaskawa SGDM
    By ferdi_mcrohl in forum LinuxCNC (formerly EMC2)
    Last Post: 06-01-2010, 02:40 PM
