Hi All,
I've noticed a problem when trying to measure turned threads. When I measure threads using the 3 wire method the threads measure nominal according to the chart that came with the wires. But our go/no-go ring gauges don't fit the threads. I have to run the threads to the minimum measurement over wires in order to make the go gauge fit. I've checked the thread profiles on our optical comparator and they seem to check out as far as the Vee being 60 degrees and perpendicular to the axis of the bar. Can anyone explain why the gauges and the wires differ so much?
