584,858 active members*
4,372 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Cheap hobby servo for small motors
Results 1 to 6 of 6
    Jul 2005
    261
    Is there any cheap hobby boards for little servo motors? I'm trying to build an automatic cigarette stuffing machine, and I found a mechanism at a flea-market, but it has gearhead servo motors. I'm used to using stepper drivers and it would be too much work to convert it to steppers.
    WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
    Dec 2003
    24216
    Are they DC, AC type of feedback if any?
    Al.
    Albert E.
    Jul 2005
    261
    Its just a dc motor with a quadrature encoder. 2 lines power the motor, and 4 for the encoder. Encoder power+,ground, and the two bit signals.
    Dec 2003
    24216
    A conversion would be dependent on the ratio and if the mount and if the shaft size was fairly standard and was not splined etc?
    I assume you want step/dir, Mach?
    There are quite a few servo controllers out there that should be capable.
    I would keep the servo's, but then I'm biased!
    Al.
    Albert E.
    Jul 2005
    261
    Its not a milling machine or 3x mill or lathe. I want step/dir inputs - for these servo d/c motors with quad encoders that use probably 1 amp of power.
    Dec 2003
    24216
    It would appear you just want point to point control? is this a preset repetitive application, IOW, once programmed does not need any positioning or program info from an operator?
    What operator interface or controller do you intend using?
    Al.
    Albert E.
  1. DIY hobby small plastics mill/router
    By RomanLini in forum CNC Wood Router Project Log
    Last Post: 04-19-2012, 08:16 PM
  2. Help me pick machines for small hobby-ish shop.
    By joshuadreed in forum Uncategorised MetalWorking Machines
    Last Post: 09-06-2010, 06:17 AM
  3. Looking for small cheap stepper motors
    By abbtech in forum Want To Buy...Need help!
    Last Post: 10-27-2009, 02:55 AM
  4. Small scale hobby hotwire CNC.
    By bkboggy in forum CNC Wire Foam Cutter Machines
    Last Post: 02-13-2009, 04:22 AM
  5. Hobby milling machine - with a small budget
    By Siress in forum Uncategorised MetalWorking Machines
    Last Post: 02-27-2007, 11:12 AM
