586,009 active members*
4,905 visitors online*
IndustryArena Forum > Community Club House > Riddle me this, can anybody guess what this is?
Results 1 to 10 of 10
    Apr 2008
    18
    Normally I am the go to guy to know figure out what things are and how they work. Well someone brought me something from a closed down machine shop that I have not seen before, no marks, no part numbers, nothing to identify what or who made it.
    What is known, Hardened steel, TiN coated,
    Anyways I will spare you any more vague details, take a look at the pictures and help solve the riddle.
    Attachment 182916
    Attachment 182918
    Attachment 182920
    Attachment 182922
    Mar 2013
    131
    Dude, those are parts from a couple of light sabers. So damn obvious.
    Apr 2008
    18
    Wheres my head, I should have known that one, must have been used by some heavy duty mechbots, at 12 pounds each i don't think any of us would be swing these around for very long.
    Jul 2003
    1754
    Looks maybe like some sort of rotary shear for cutting strips of something?
    shredder rollers ?
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Dec 2008
    3109
    They are internal broaching tools
    possibly to do the large crank radius on an engine's con rod ( as an example )
    Some other examples
    Apr 2008
    18
    Glad to see I am not the only one that hasn't seen this before, shredder, maybe but doesn't seem to have enough cutting bite. I was leaning towards a broaching tool also or a reamer. One appears to have been used while the other doesn't, the one that has been used has minute scratches running parallel with the length of the rod. hmmm, anybody else?
    Feb 2007
    664
    Quote Originally Posted by Superman View Post
    Some other examples
    I'd have to agree with you
    Apr 2008
    18
    I would most likely agree with it being a broaching tool of sorts, but what is confusing is the void in the middle and what appears to be a mounting hole. It does start out at a diameter of 1.705" and finally to 1.905" with each cutter increasing in size by 0.0075".
    Would like to know what type of machine this would go to.
    Dec 2008
    3109
    Quote Originally Posted by X7racer View Post
    Used on a ram type of machine ( vert. or horiz. ) ...... PDF ... looks very similar
    & a Chinese site with a few extra broaches to do the flat zones on the side ... link
    these machines were a b$tch to maintain....so many sharp edges, Band-aids were always on backorder.
    for each round "tooth", it would be plunge ground to be able to give it a back clearance, the nicks are a chip breaker, no nicks in the last couple of finishers
    - used in a flood of neat, thick oil
    I knew a guy that lost his arm ( just above elbow, early 70's ) by being too close to a horizontal ram type machine. Got it caught between the external stiffening webs of the slide & an outrigger on the base. Didn't even make the m/c skip a beat
  1. I guess this forum is dead
    By bret4 in forum Syil Products
    Last Post: 04-27-2013, 02:50 AM
  2. I guess I will convert my G0704 too
    By mrcodewiz in forum Benchtop Machines
    Last Post: 11-21-2012, 05:21 PM
  3. Metal casting riddle
    By drescher3 in forum Casting Metals
    Last Post: 11-19-2008, 05:14 PM
  4. Riddle me this: electrical anomaly
    By LenMcC in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 08-16-2008, 12:58 AM
  5. Casting Riddle
    Last Post: 12-28-2007, 04:37 PM
