585,715 active members*
3,846 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > KFlop with KAnalog Step and Dir for Yaskawa SGDH PULS/SIGN inputs
    Nov 2011
    30
    I need to determine how to connect the STEP and DIR signals from KFlop JP4/JP6 (muxed because I am using KAnalog) to Yaskawa SGDH servo drives.
    Yaskawa Docs:
    Reference by Pulse Input
    Positioning is controlled by entering a reference pulse for a move.
    Attachment 183122
    Any of the following forms can be used for the position reference:
    • Line-driver output
    • +12V open-collector output
    • +5V open-collector output
    From the KFlop docs
    Configuring Step and Direction Outputs
    I see that setting the Output Chan 0 is Open Collector type output and it should work best for driving opto inputs. But, since I am using KAnalog, I also read that Output Chan 0 and 2 cannot be used for Open Collector output because they have the 150 ohm pull down resistors. I plan on using the JP5 from KAnalog for 4 differential encoder index pulses.
    What should I do?
    Has anyone used KFlop w/KAnalog to drive Yaskawa drives in position mode?
    Nov 2011
    30
    I am sorry. I jumped the gun when I started this thread. I was still in the STEP DIR design mode from only having KFlop. Now that I am getting KAnalog, I will just use the drive's VREF for Speed control mode and take advantage of the KAnalog DAC's.
  1. My Kflop/Kanalog test bed
    By PEU in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-31-2013, 04:55 PM
  2. Retrofit old Cnc with kflop-kanalog
    By Scottburley in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-23-2013, 12:49 AM
  3. KFlop + KAnalog hardware details
    By arvidj in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-28-2012, 08:53 PM
  4. Yaskawa SGMG and SGDH
    By stang623 in forum Servo Motors / Drives
    Last Post: 10-02-2012, 07:40 PM
  5. YASKAWA SGDH-30DE
    By vipinsumitha in forum Servo Drives
    Last Post: 12-07-2009, 03:56 PM
