585,712 active members*
4,068 visitors online*
Results 1 to 11 of 11
    Nov 2012
    15
    Error while tapping
    We are trying to tap 3 off M10 x 1.5 hole using a Fagor 8055i control and BobcadV25 when we run the Prog it does the
    C/Drill (Canned) then the Tap Drill (Canned ) but when it gets to the Tapping (Canned) it comes up with Error code 0006
    which says there is a minus value somewhere where there should only be a Positive.
    The line reads
    N88 G84 G98 X0. Y0. Z2.54 I-17.913 K0.5 R1 J100 F1.5 S200
    and this seems to be correct or am I missing something as the other Canned part of the Prog run fine.
    The co-ords are in G90.
    Can anyone see or know where the error could be.
    Jul 2003
    1220
    Try this block
    N88 G84 G98 X0. Y0. Z2.54 I-17.913 K5 R1 J1 F300 S200
    Warning...check if correct
    Nov 2012
    15
    Thanks Kiwi,
    Nov 2012
    15
    Thank Kiwi,
    That made the machine go thru the moves and NO error so I will try on the part later.
    Jock
    May 2006
    39
    I'm having the same problem tapping with a 4-40. I have tried both of the below lines of code. I'm guessing the F value is the problem. What should it be?
    N439 G84 G98 X0.25 Y-0.25 Z0.1 I-0.2008 K0. R1 J1 F0.025 S500
    N439 G84 G98 X0.25 Y-0.25 Z0.1 I-0.2008 K0. R1 J100 F0.025 S500
    Jul 2003
    1220
    My guess without trying:
    N439 G84 G98 X0.25 Y-0.25 Z0.1 I-0.2008 K0. R1 J1 F12.5 S500
    Nov 2012
    15
    Go with Kiwi's info it worked for us.
    Nov 2012
    15
    Kiwi just explain to CM the way you get the F value as I am away for awhile.
    Jul 2003
    1220
    Quote Originally Posted by Jock's Trap View Post
    ....explain to CM the way you get the F value.....
    As the thread is 40 TPI, the F value needs to be one fortieth of the S. eg. 500/40 = 12.5
    Dec 2008
    3109
    Quote Originally Posted by Kiwi View Post
    Why don't you guys use a G95 before the cycle...... the F will always be the pitch of the thread, the S can be altered without having to re-calculate the feed
    NOTE.... always have a G94 ( feed per minute ) placed in the header & after any tool that uses G95
    May 2006
    39
    This seems to work. I had to add a 5 to the K value. I don't get the error anymore and the machine goes through the motions. My tap broke but I think I need one of those floating tap holders. BobCad does not seem to be able to modify the post to output the code properly though.
  1. HELP - BP VMC1000 Rigid Tapping Cycle Error
    By shaffin in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2013, 05:21 PM
  2. Error #7 rigid tapping
    By dav612 in forum Fadal
    Last Post: 01-17-2012, 03:27 AM
  3. Replies: 13
    Last Post: 07-04-2009, 12:43 AM
  4. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
