I've been slowly working on the momus v2 build. a couple of weeks ago the first carriage block assembly went perfectly: part 16 was perpendicular to part 13 after driving the tension pins. then I drilled holes the tension pins for part 17. it was still perpendicular and I drove the tension pins home.....it was obviously out of square--measuring indicated about 50mils out. I didn't want to pry the parts apart and drill 3/16" holes on opposite diagonals and I didn't have extra aluminum. Therefore, I decided to order some extra Al and also decided to buy some 2" and 0.625" stock to used as a jig to clamp parts 16 and 17 together while drilling holes for and driving the pins.
tonight I assembled the lower, left, and right carriage blocks with the 2.625" spacer Al. Excellent outcome. well, that is until I noticed that I had assembled it with the lower carriage block's 1/4-20 bearing block holes (for part 14) offset toward the front instead of toward the back.
so, the questions arise: will this offset pose to be problematic. If so, I have the option of making three new parts (13, 16, & 17) or pounding out the tension pins and drilling new holes. would there be enough material left (strength) if I drill new 3/16" holes on opposite diagonals? (The former is probably acceptable.) what would you do?
much appreciated.
greg
kimnach.org
