If this has been discussed previously I would appreciate a link to the thread.
I want to attach an UPS to my Tormach computer so if I lose power at least the computer will stay on and I can shutdown normally.
Questions:
1. If I just take the normal 120 vac power cord coming out of the Tormach and connect to the UPS the pro is that the computer switch on the control panel will work normally and I will be protected. The con is that if the power goes down the coolant pump will drain the UPS. And there is the possibility that the pump will draw more then the size of the UPS and damage it. (With the instructions for the UPS it warns about such a possibility). So does any one know what the power usage of the pump is or what is the horsepower of the pump motor.
2. I could disconnect the computer and monitor from the Tormach system and plug them directly into the UPS. Pro is that the pump is not on the UPS. Con is that you can no longer turn the computer and monitor on and off from the Tormach panel.
3. Rewire the Tormach control box to separate the pump and computer switches and give each a separate power cord. Pro you get everything you want. Con is that you could void the warranty.
Looking for answers to my questions and also if others are using a UPS or anything else you can share about the subject.
