585,902 active members*
4,219 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X3/SX3/G0619/G0463 > Smooth Stepper Ethernet Board - Mach3
    Oct 2010
    94
    Hopefully someone else has got some experience with these things. Again no instructions supplied with the "kit" i got, or with the smooth stepper..
    Its plugged in, im getting two short Flashes, and a pause, the two short flashes, as if its in "wake-up" mode. The documentaiton says its going to be running with an IP address of 10.9.9.9 I've set up my network so i can reach that, but when i ping it. ( ping 10.9.9.9 ) i don't get any response.
    Will it in fact repsond to a ping?
    I have a C25 board to plug it in, from cnc4pc.com i'm hoping i've got the ports set up right.. Again theres a real lack of documentation. I was sent a diagram for a differnet controller, to the the one that i got.
    ANy clues appreicated.
    Dec 2005
    238
    While I don't have the Ethernet version of the smooth stepper I am wondering if you have loaded the Ethernet SmoothStepper plugin which Mach3 uses to control the smooth stepper.
    Plug in is available here. Software
    Once you are talking to the smooth stepper you can start pulling your hair out over the C25 board.
    Hope this helps
    Cheers
    Peter
    The ingenuity of idiots is unlimited.
    http://www.youtube.com/user/cncnutz
    Oct 2010
    94
    Got the Smooth Stepper Ethernt ruuning... And yest it will respond to a ping, as long as you have a version 1 or higher board.
    Dec 2005
    238
    Nice one. Good to see you got it going.
    Just noticed you're in NZ.
  1. Replies: 4
    Last Post: 11-15-2014, 08:14 PM
  2. C10 and Smooth Stepper Board...Need Help
    By Whizbang in forum Benchtop Machines
    Last Post: 10-21-2012, 06:25 AM
  3. Replies: 1
    Last Post: 10-05-2012, 12:24 PM
  4. HiCON CPU ethernet board for Mach3
    By Mike4703 in forum Controller Cards
    Last Post: 06-20-2012, 03:21 AM
  5. Replies: 0
    Last Post: 09-27-2011, 03:34 PM
