585,996 active members*
3,850 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut2D / Cut3D > What this soft is able to do in thick aluminium
    May 2013
    59
    Hi all,
    I mill a thick aluminium brackets thanks to CUT 2D, I share my experience with it:
    Homemade CNC router, tutorial from Design to Finish Part - YouTube
    Hope it will help
    Apr 2013
    Aluminum?
    You genreated G code with two tools, which was used to mill the part?
    It looked like the cuts were not ramped in. Did the tool have the capablity to make a ramp cut (changing Z while X or/or Y changes)?
    Great music.
    Thanks for the effort to show us your work.
    May 2013
    59
    Hi Petebo,
    No it is heavy plastic (PVC). I used a 2 flutes end mill carbide with center cut. So I do not need ramp down but I have to slow down the Z feerate.
    Thanks for your comments.
    If you want to see aluminium milling see this video:
    https://www.youtube.com/watch?v=uXh7voTKkJ8
    The CNC is stiff enough to support up to 22 ipm of feerate with 1/4' end mill diameter and 0.02" deep.
  1. Replies: 5
    Last Post: 09-12-2012, 03:09 PM
  2. Aluminium passivation - for aluminium to be used outside
    By hudsonlighting in forum Mass finishing equipment/media/strategies
    Last Post: 04-06-2011, 06:06 PM
  3. Anyone tested milling soft aluminium with Joes CNC?
    By Viperia in forum Joes CNC Model 2006
    Last Post: 10-11-2007, 03:10 AM
  4. Recommendations for milling thick aluminium
    By Rhodan in forum Mechanical Calculations/Engineering Design
    Last Post: 09-04-2006, 02:14 AM
