585,715 active members*
4,077 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Cincinatti Milacron Retrofit Problems
    May 2013
    I have a Cincinatti Milacron retrofitted with a Fanuc 21 control. It recently started throwing up the 411 alarm on X whenever it was taking a cut. Checked the motor it megs out fine and ballscrew turns pretty easy. While trying to get it to run the other day i could smell something burning. Powered down and opened cabinet and seen smoke coming from one of the boards. It is Siemens 6sc6100-0ga00 board. Two diodes (v379 and v380) are crisp. I bought another board haven't installed yet for fear of burning it as well. What could cause this? Bad Cables?
    Jun 2004
    511
    Check the motor from the drive end of the motor leads, that should tell you.
    May 2013
    Motors and cables to motor look good.
  1. Cincinatti Milacron Arrow 1000 Tooling Error
    By david_culler in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2015, 01:10 AM
  2. cincinatti cnc retrofit
    By secondcircuits in forum Cincinnati CNC
    Last Post: 02-20-2013, 04:09 PM
  3. Cincinatti Milacron 5VC-750
    By pgarr54932 in forum DNC Problems and Solutions
    Last Post: 12-01-2011, 01:35 AM
  4. cincinatti milacron arrow 750
    By kevmor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-11-2008, 04:10 PM
