Originally Posted by
OkumaWiz
You will need to look in your parameters for a page with pictures of your chuck and center on it. Set the center work bit to 1 and your tail stock should come to life. M56/M55 will also adv/retract it. If you need to rotate the spindle with the quill retracted,use M157 to turn center work interlock OFF.
Best regards,
- - - Updated - - -
Best regards,
